1991 Acura Integra rear tire uneven wear
1991 ACURA INTEGRA
239,000 MILES • 4 CYL • FWD • AUTOMATIC
WALLEYEJJ
Uneven rear tire wear. Inner tires wear down to chords with half thread still 0on outer part of tires. Like a castor or camber problem typically associated with the front end.
Jul 2, 2010 at 12:30 PM
KHLOW2008
  • 41,814 POSTS
Hi walleyejj,
The rear toe-in can be adjusted but the castro or camber dpends on the linkages. You would need to check the arm bushes and the struts for abnormalities.
An alignment would help.
Jul 3, 2010 at 7:34 PM
