1991 Acura Integra No injector pulse.
212,000 MILES • 4 CYL • FWD • MANUAL
BORISD
I replaced the distributor and still the same simptom comes up, one pulse from injectors and never again. this is a 91 integra but has a distributor from a 92 and the connectors are not the same. the connectors have been switched over by the previous owner. i have looked to make sure it is wired properly and everythin looks fine. what else could be the problem. I have also replaced the ecu and main relay and still nothing.
Oct 20, 2009 at 2:44 AM
F4I_GUY
  • 3,302 POSTS
Are you getting battery power to all 4 injectors? Have you measured resistance across them yet?
Oct 20, 2009 at 2:53 PM
KHLOW2008
  • 41,812 POSTS
Did you check if the timing belt had given way?
Oct 21, 2009 at 1:43 AM
