1991 Acura Integra no compression
IMPORTPRINCEZZ
  • 6 POSTS
Engine Performance problem
1991 Acura Integra Automatic
i just bought a 91 acura integra and it cranks but doesn't turn over. i checked timing and it is right on time however when i did a compression test there is no compression. would a valve job fix that or is there something else it could be??
May 21, 2008 at 4:19 AM
THEBIGGMCDOG
  • 25 POSTS
Did the car over heat? if it did it sounds as if the head gasket blew out.
May 26, 2008 at 5:09 AM
KHLOW2008
  • 41,812 POSTS
If all the cylinders have no compression, a valve job would not do unless cause are due to bent valves..
Did you try a wet test to see if the compression increases?
You mentioned timing is ok, so I take it there is nothing wrong with the timing belts as a snapped timing belt would not give much compression.
May 26, 2008 at 6:00 AM
IMPORTPRINCEZZ
  • 6 POSTS
[quote:570445663d="KHLow2008"]If all the cylinders have no compression, a valve job would not do unless cause are due to bent valves..
You mentioned timing is ok, so I take it there is nothing wrong with the timing belts as a snapped timing belt would not give much compression.[/quote:570445663d]
none of the timing belts are snapped..no i didn't do a wet test..never heard of that?!
May 28, 2008 at 5:59 AM
IMPORTPRINCEZZ
  • 6 POSTS
[quote:580cf87350="thebiggmcdog"]Did the car over heat? if it did it sounds as if the head gasket blew out.[/quote:580cf87350]
not sure if the car overheated...just bought it.
May 28, 2008 at 6:02 AM
KHLOW2008
  • 41,812 POSTS
Hi there,
Wet test means pumping some engine oil into the cylinder via the plug holes and testing the compression again.
When you bought the car, was the engine running well?
May 29, 2008 at 2:36 AM
IMPORTPRINCEZZ
  • 6 POSTS
no the engine wasn't running at all.
Jun 3, 2008 at 4:29 AM
KHLOW2008
  • 41,812 POSTS
Hi importprincezz,
So you had no idea of the history of the vehicle.
Since the engine might have not been running for a long time, the compression might be missing due to dry cylinders.
Just do the wet test as I mentioned and see if you can get the compression.
Jun 4, 2008 at 1:58 AM
IMPORTPRINCEZZ
  • 6 POSTS
okay will do! the only thing i do know is that the car has been sitting for a long time soo that might be it. thx
Jun 12, 2008 at 4:20 PM
