My turn signals are messed up.If you turn on the right turn signal the right and left flash.If you turn on the left turn signal the left and right flash.If you turn on the headlights and the right turn signal it works perfect.If you turn the headlights on and the left turn signal the left works good but the right turn signal goes out.What's my problem?I checked all fuses and switches and wires.The other thing is my hazards do not work.As soon as I turn one of the turn signals on and then turn the hazard on the turn signal stops working.Help.I need my car to work properly.thanks
Apr 15, 2009 at 7:15 PM
