1991 Acura Integra loud noise
JESSEG
  • 1991 ACURA INTEGRA
  • 6 CYL
  • MANUAL
  • 10,000 MILES
When I start to drive right before I hit 2 on the rpms There is a lound noise that sounds almost like a belt noise but I checked the belts they are fine, but I did notice that one of the wheels or the pulleys that the belts go around actually the smallest wheel looks like it has a peice or a chunk missing, would that cause the same noise as the belt.
Friday, October 17th, 2008 AT 11:30 PM
KHLOW2008
  • 41,814 POSTS
Hi jesseg,
The idler pulley bearing if faulty would also cause the belt noise. For ribbed belts, the tension should be more than normal v-belts and I normally twist the longest part to test. If there is insufficient tension, it would cause the noise.
The crankshaft if equipped with dynamic balancer would cause the noise if the damper is bad.
Monday, October 27th, 2008 AT 1:30 AM
JESSEG
Alright I will check on that thank you for the info I will make a donation as soon as I can thanks you guys are great
Monday, October 27th, 2008 AT 9:27 AM
KHLOW2008
  • 41,814 POSTS
Hi jesseg,
You are welcomed and thank you too.
Have a nice day.
Monday, October 27th, 2008 AT 10:02 AM
