1991 Acura Integra loose shifting
1991 ACURA INTEGRA
JON6942
Transmission problem
1991 Acura Integra 4 cyl Two Wheel Drive Manual
i was wondering if i can adjust or tighten the shifter linkage. there is way too much "play" in the shifter. sometimes when i think im in 1st gear im really in 3rd and 3rd gear i am bearley able to engage it when the rpms are over 2500 when shifting from 2nd to 3rd gear it grinds the gears going into 3rd gear but if i let the rpms drop a bit b4 shifting from 2 to 3 gear its smooth but does not feel like it is fully engaged. it has not poped out of gear. sometimes i dont know what gear im in until i let out the clutch
Mar 10, 2009 at 2:26 PM
DOCFIXIT
  • 18,828 POSTS
No external adjustment. Problem will require tear down and replace worn parts.
Mar 11, 2009 at 2:55 AM
