1991 Acura Integra Idle Problems
160,000 MILES • 4 CYL • FWD • MANUAL
BENJAMIN22
The car drives fine untill you come to an idle or stop. Then it dies. It starts back up after a little bit but then dies again at idle. Pretty much have to keep constant gas to it. What could that be?
Jun 11, 2008 at 3:47 PM
KHLOW2008
  • 41,812 POSTS
Hi Benjamin22,
The idling rpm is set too low. If the AC is switch on, the rpm drops very low or stalls, then you need to have the throttle body and EACV cleaned.
Jun 11, 2008 at 11:18 PM
