1991 Acura Integra Hole in piston number 4 wall
1991 ACURA INTEGRA
HARMES04
Engine Mechanical problem
1991 Acura Integra 4 cyl Front Wheel Drive Manual
I have a hole in the wall on piston 4
its a jdm b18a1 integra motor and I was wondering how to fix it
can I just replace the bottom
can I just replace the head
Do I have to replace the whole engine
can I just have a certified mechanic fix the wall
I need answers as soon as possible please let me know if you can help at all
Sep 26, 2008 at 7:47 PM
can I just replace the bottom . You might as well get a short block
Sep 26, 2008 at 9:34 PM
HARMES04
alright so you are absolutely sure that I wont need to replace the head. I know you just told me to get a shortblock but I just want to be sure
Sep 27, 2008 at 3:18 AM
KHLOW2008
  • 41,814 POSTS
You need to remove cylinder head to confrim if there are any major damages to it. A broken connecting rod can cause damages to the head too.
You cannot repair a hole iin the cylinder block.
Sep 27, 2008 at 3:26 AM
How did you know that there's a hole on no.4 cylinder?
If you went thru the head you will know if there's damages there
To get there-you have to remove the head or the crankcase cover
Anyway to fix this fast-Get a new engine
Sep 27, 2008 at 7:19 AM
HARMES04
yeah I took it to the mechanic and he said that there is a lack of compression in the bottom end and that there is a hole in the wall on piston 4. He didnt talk about any damage anywhere else he just explained that I would have to replace the bottom end.
Sep 27, 2008 at 7:57 AM
