1991 Acura Integra Fuel Injector
212,000 MILES • 4 CYL • FWD • MANUAL
BORISD
I am not getting any injector pulse.
When I put a noid light on the injector harnes the light only comes on once when I initialy crank the engine and never comes back again. Fuel is at the fuel injectors and spark is available to all spark plugs.
What could be a problem?
Oct 6, 2009 at 3:24 PM
DOCFIXIT
  • 18,828 POSTS
Most likely the crank sensor inside Dist. If PCM does not receive crank motion it shuts inj. off. Crank should Ohm out 600-950 ohms
Oct 7, 2009 at 2:44 AM
BORISD
I replaced the distributor and still the same simptom comes up, one pulse from injectors and never again. this is a 91 integra but has a distributor from a 92 and the connectors are not the same. the connectors have been switched over by the previous owner. i have looked to make sure it is wired properly and everythin looks fine. what else could be the problem. I have also replaced the ecu and main relay and still nothing.
Oct 14, 2009 at 4:13 AM
