1991 Acura Integra ECU
1991 ACURA INTEGRA
MAXMACIAS
Electrical problem
1991 Acura Integra 4 cyl Two Wheel Drive Manual 200K miles
Under glove compartment i believe ECU is making a noise car will not start and all power is dead. Acciendtly crossed battery cables. Would Fuse Link burn first or ECU? Is there a relay in that area that is causing that noise on my acura integra 91 GS
- Max
Oct 2, 2008 at 6:29 AM
KHLOW2008
  • 41,814 POSTS
Hi Max,
Normally the fuse would go first but if you had left the ignition switch on, the ECM could be fried.
Since you have no power supply, check the fuses, battery terminal connections and groundings first.
Oct 2, 2008 at 7:48 AM
MAXMACIAS
Thanks it was fuse link replaced it and it worked
Oct 2, 2008 at 10:23 AM
KHLOW2008
  • 41,814 POSTS
Thank you for the feed back.
Oct 4, 2008 at 12:48 AM
