HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Acura
Integra
Electrical
Battery
Replace/Remove
1991 Acura Integra
MESSAY2109
MEMBER
1991 ACURA INTEGRA
4 CYL
2WD
AUTOMATIC
171,000 MILES
I made a mistake when changing my battery I crossed the terminal now nothing in the car works how can I fix this problem
Wednesday, January 30th, 2008 AT 4:28 PM
2CARPRO JACK
MECHANIC
Check all fuses and fusible links near the battery and in the car to start. Im sure you will find something popped
Thursday, January 31st, 2008 AT 8:25 AM
Please
login
or
register
to post a reply.
Related Battery Replace/Remove Content
1993 Acura Integra Battery
I Have A 93 Integra Gsr.I Try To Change The Start But I Was Given The Worng Starter. So I Put My Old One Back On. I Hook Everything Back. I...
Asked by
villevang
1 ANSWER
1993
ACURA INTEGRA
VIDEO
Battery Replacement
Instructional repair video
GUIDE
Battery Replacement
Replacing a car battery is easy to do and will take about 20 minutes in most cases, this job can be done using everyday tools. Please wear protective gloves and eyewear when...
1987 Acura Integra Battery Keeps Dying....
Well Here Is The Problem. Car Runs Great, Though When I Turn On The Headlights And Interior Lighting When The Car Is Idling Around 1 Grand...
Asked by
thor98337
1987
ACURA INTEGRA
I Crossed The Battery Cables When Jumping
How Much Electrical Damage Would Occur If The Jumper Cables Are Reversed, Even Though The Jumped Battery Was Extremely Dead? The Acura...
Asked by
alaner69
2009
ACURA INTEGRA
2000 Acura Integra Jump Start Wrong
Hooked Up My Jumper Cables Wrong. The Car I Was Using To Jump Start My Dead Car Was Hooked Up Right. Her Battery Started Smoking, Not Mine...
Asked by
mis_sasi
2000
ACURA INTEGRA
1999 Acura Integra Car Will Only Jump, And Sometimes...
Thank You So Much For Your Help- I Just Pushed This Car 2 Miles Down The Road Because It Died And Am Freaking Out Because I Have No Idea...
Asked by
Jmorris30
1 ANSWER
1999
ACURA INTEGRA
VIEW MORE
Battery Replacement Saturn
Battery Replacement Honda
Battery Replacement Dodge
