1990 Acura Integra Turn Switch
1990 ACURA INTEGRA
CMARQUIS
Electrical problem
1990 Acura Integra 4 cyl Automatic 200,00 miles
When I turn my lights on and turn my left blinker on my dash lights will go out and so will my brake lights. When I finish making the turn and the blinker switches off the lights will both continue to stay out untill I turn my lights off and than back on. Some times it will take more than one try to get all the lights on when I turn them on and off. Rarely will the lights continue to work after I im finished making a left turn. I want to know if its the Turn Switch its self that needs to be replaced before I spend 140.00 on a new one.
Sep 4, 2010 at 11:47 AM
KHLOW2008
  • 41,814 POSTS
Hi cmarquis,
Symptoms does indicate a fault with the switch.
At the switch, test for battery voltage at the Red/Yellow ( low beam ) and Red/Blue ( high beam ) when the light switch is on and the lights do not come on. If no voltage are availabkle and there is voltage at the White wire, then the switch is bad.
Sep 8, 2010 at 3:53 AM
