1990 Acura Integra reving
LOGANHATCH
  • 1990 ACURA INTEGRA
  • 4 CYL
  • FWD
  • MANUAL
  • 200,000 MILES
I have a 1990 Integra with a 1.8 liter engine. The problem is that when I turn it on it reves up and down from the idle to 3 to 4 grand then it holds there for like 10 min then it just goes up and down after a while. Dont know what to check.
Friday, October 3rd, 2008 AT 11:53 AM
KHLOW2008
  • 41,814 POSTS
Hi loganhatch,
The cold start fast idle valve, throttle body and EACV are the 3 items you need to check.
1. Fast idle valve most probably has its internal valve worked loose by itself due to a bad O ring.
2. Throttle body might be stuck in open position due to debris from a bad air filter.
3. The EAVC might be stuck in open position due to internal fault.
Sunday, October 26th, 2008 AT 7:58 PM
