1990 Acura Integra rear wheel alignment
1990 ACURA INTEGRA
MIKEW44452
1990 Acura Integra
I have a acura integra 1990 and the rear passenger wheel is tipped inward at the top and it is wearing the tires. Is there a way to correct this?
Oct 24, 2008 at 10:26 AM
KHLOW2008
  • 41,814 POSTS
Hi mikew44452,
The rear cambers are out of specs and
1. Check the lower control arm bushes for wear and adjustment.
2. Check upper arm bushes for wear.
If both are ok, you need to readjust the camber by adding shims to the upper arm mounting area.
Oct 26, 2008 at 7:29 PM
