1990 Acura Integra Radiator problem please help.
1990 ACURA INTEGRA
POKIN8
Engine Cooling problem
1990 Acura Integra 4 cyl Automatic 111000 miles
i know absolutely nothing about cars, but i am willing to learn. i have a 1990 acura integra LS and my radiator has some small leaks on the corners right by the cap, i fill the tank with 50/50 antifreeze but it depleets everyday and i just keep filling the tank, but theres no coolant on my driveway, my mechanic says i need a new radiator, i have 111,000 miles on it, one of my co workers suggested i use jb weld to seal those corners. what do you guys think?? also is there an extended maintanance list for the acura integra LS? My manual only goes to 90,000. also i have a lot of black gunk built up underneath the engine, i just replaced my timing belt and gasket, could that gunk be from the other gasket?? also i havent had a tune up in 4 years and need one any suggestions on plugs and wire i should use?? thanks guys. i appreciate any help i can get.
Jul 6, 2008 at 4:47 PM
DOCHAGERTY
  • 9,606 POSTS
I would recommend replacement of the radiator, repairing it is just putting a band aid on a problem that really needs to be addressed with a new radiator as well as a new thermostat. As to the maintenance schedule, it just keeps going. Oil and filters at whatever interval the manual recommends and so on. The possible oil leak is difficult to diagnose from cyberspace, cleaning and repair might best be left to trained technicians. A tune up with Original equipment or replacement parts might best be left to your own discretion, your mechanic might be a good place to go.
Jul 6, 2008 at 6:49 PM
