1990 Acura Integra neep a lot of help??
1990 ACURA INTEGRA
100,000 MILES • 4 CYL • FWD • MANUAL
SESSIONSMOTORSPORTS
hello, i have a 90 acura integra im having a lot of trouble making my car to start. my qeuestion is wen i try to turn my car on it will start but it keeps turning off so i try again now pumping the gas and ill stay on but wen i let go off the gas it turns off , the ecu is trowing code 14 which is the iac sensor if i change the sensor will it fix my problem???
Feb 8, 2010 at 6:39 PM
  • 31,937 POSTS
Hi there,
A faulty IAC will result in a stall condition, i would start with doing this valve.
Mark (mhpautos)
Feb 8, 2010 at 6:45 PM
