1990 Acura Integra HOW TO IDLE INTEGRA UP or DOWN
1990 ACURA INTEGRA
MARCUSMEADE
1990 Acura Integra 4 cyl Two Wheel Drive Automatic
HOW DO I IDLE MY 1990 ACURA INTEGRA UP. IT IDLES BELOW THE 1 ON RPM. CAR and STEERING WHEEL SHAKES AT STOP LIGHTS and STOP SIGNS AS THE RPM DROPS BELOW 1. WANT TO IDLE UP
Mar 30, 2010 at 8:16 AM
KHLOW2008
  • 41,814 POSTS
Hi MARCUSMEADE,
The idle adjust screw is located on top left of the throttle body, a bronze screw.
The idling speed is correct now and increasing it can cause surging, especially when the the engine is starting to warm up after a cold start.
The vibrations that you are experiencing are due to bad engine mounts and getting them replaced would be the correct way to eliminate the vibrating issues.
Mar 31, 2010 at 2:24 AM
