1990 Acura Integra hey
175 MILES • 4 CYL • 4WD • MANUAL
TEGGY4LIFE
umm what does it means when your car idles to 2 grand then goes back to normal ? or when your third gear grinds ?
Dec 2, 2009 at 11:12 AM
ARISTOTLE
  • 13 POSTS
Check idle air control vavle behind intake manifold; because its old, carbon deposits build up inside it or just replace it. The third gear in all Honda 4 cylinder transmissions is a common thing to have a problem with, usually the synchros go bad but because its old. It would probably be cheaper to replace the transmission.
Dec 25, 2009 at 8:21 AM
MY1STTEG
  • 6 POSTS
[quote:6d764c330d="teggy4life"]Engine Mechanical problem
1990 Acura Integra 4 cyl Four Wheel Drive Manual 175 miles
umm what does it means when your car idles to 2 grand then goes back to normal ? or when your third gear grinds ?[/quote:6d764c330d]
CHECK YOUR TRANSMISSION FLUID AND CHECK YOUR IAV AND FITV SENSOR ON YOUR INTAKE MANIFOLD FOR THE IDLE PROB
Jan 2, 2010 at 3:24 PM
