1990 Acura Integra cooling fans
72MCQUEEN
Engine Cooling problem
1990 Acura Integra 4 cyl Two Wheel Drive Manual
I have a 1990 acura integra and both my cooling fans don't come on.My car will get close to the hot but won't et hot to were it is over heating.Now my radiator fan was working before but now it's not since I recently got my ac charge......
May 27, 2008 at 4:49 AM
KHLOW2008
  • 41,812 POSTS
Hi 72Mcqueen,
Does the radiator fan come on when the AC is turned on? If not then you need to check both
motors if they are faulty.
If the fan works with AC on, then you need to check the fan relay and thermosensor.
Jun 1, 2008 at 12:19 AM
