1990 Acura Integra Code 4, Code 8
1990 ACURA INTEGRA
DADDMMD
Computer problem
1990 Acura Integra 4 cyl Front Wheel Drive Manual
Was setting code 4,crank angle sensor, would not go above 3200 rpm. Moved car, shut down, went back a few hours later, tried to start, now kicks occasionally like it wants to start, but won't keep running, now setting code 8, TDC. Previously changed distributor, w/ new cap and rotor. Was setting code 4 prior to change. Still did after. What's up?
Feb 26, 2009 at 12:38 AM
F4I_GUY
  • 3,302 POSTS
Those codes are all related to the distributor.
It may be a faulty distributor or the circuit itself. I know you just replaced it, but it may of been defective.
Feb 26, 2009 at 9:14 AM
