1990 Acura Integra car want start
1990 ACURA INTEGRA
RELL21
Engine Mechanical problem
1990 Acura Integra 4 cyl Front Wheel Drive Manual
Hey my car want start now. I had to replace my ignition switch and after I did that now my car want start. But before my car came to this problem I had to hold my key a certain way in order for it to start. But It only started when it wanted too. can u help me by any chance
Sep 2, 2008 at 1:23 PM
KHLOW2008
  • 41,814 POSTS
Hi Rell21,
It is difficult to understand your queston.
You mean the car won't start now? Can it crank?
Are the dashlights showing when the ignition switch is turned on?
Did you blow a fuse when changing the ignition switch?
Sep 2, 2008 at 11:48 PM
RELL21
I didn't blow any fuses and the lights do come on when u switch the ignition on the dash. Its like my car wants to crank but its like it isn't getting any gas or something. Could it be a relay or something of that sort that could be a problem? Oh yea now the car will start but only when it wants too... I can start it up now then maybe after an hour or so it want.
Sep 3, 2008 at 12:33 PM
KHLOW2008
  • 41,814 POSTS
Hi Rell21,
This has nothing to do with the ignition switch.
Repair/replace the main relay and the problem should be solved.
Sep 3, 2008 at 11:51 PM
