1990 Acura Integra Car Has No Fire!!
1990 ACURA INTEGRA
190,000 MILES • 4 CYL • FWD • MANUAL
SAMPSON2286
I have changed the distributor it's self, the starter, alternator, fuel pump, fuel pump relay, plugs, wires, fuses, the engine rotates and gets fuel but no fire?
Jun 22, 2008 at 6:14 AM
KHLOW2008
  • 41,814 POSTS
Hi sampson2286,
Remove distributor cap and check if distributor rotor is turning while cranking. Is the spring at tip of coil properly installed?
Is power getting to the distributor? 12 volt at Brown/Yellow wire of distributor with ignition switch ON.
Jun 23, 2008 at 1:55 AM
