i installed after market cold air intake were would I run the vacuum lines from the dashpot and air boost valve
Friday, September 25th, 2009 AT 5:30 PM
KHLOW2008
MECHANIC
Hi draw,
The air boost valve and dashpot do not require vacumns for the lines. They original lines are plugged into the air intake hose to prevent dust from getting into them. The best way is to plug them into the cold air intake by making new connectors or alternative you can use a T joint to join up the two and instal a mini filter.
