1989 Acura Integra what do i do now
1989 ACURA INTEGRA
THEDUDE0202
Electrical problem
1989 Acura Integra 4 cyl Two Wheel Drive Manual
I have a fresh charge on my batt. and all i get is clicking so i pulled the starter and jumped it the solenoid jumped and the shaft spins what is wrong
Dec 2, 2009 at 6:04 PM
KHLOW2008
  • CAR REPAIR CONTRIBUTOR
  • 41,814 POSTS
Hi thedude0202,
Do you mean the starter cranks when battery voltage is applied to the starter soleanoid?
Check the wire connection from ignition switch to starter solenoid. Did you check the starter solenoid wire connector for firmness when installed?
Dec 3, 2009 at 7:54 AM
