1989 Acura Integra can you bypass???
THE DELL GUY
Electrical problem
1989 Acura Integra 4 cyl Two Wheel Drive Manual
I have a meter to test. but AC duct is in the way. can I jump/bypass switch (through harness) to check voltage or do I have to remove the switch altogether???
For safty purposes ONLY can it be removed knowing that clutch has to be depressed to start car.
If test OK, how do I adjust to proper adjustment setting?.
Sep 22, 2008 at 6:02 AM
KHLOW2008
  • 41,812 POSTS
Hi THE DELL GUY,
Sorry to say that I do not understand what you are trying to ask.
Voltage testing is done in parallel so no need to remove anything, just tap into any wire or connector that you want to test for voltage.
Sep 23, 2008 at 3:48 AM
