1988 Acura Integra perhaps the alternator?
101,000 MILES • 4 CYL • 2WD • AUTOMATIC
PASCIBERRAS
Hi, 1988 acura
I inherited a 1988 acura with under 88000 miles. runs pretty well. problem now is it wont turn over. i jus t replaced the battery & it still wont kick. alternator or worse? it's gottten it's oil change & tlc since coming home. what do you think?
Jan 21, 2008 at 4:28 AM
JEREMIAH
  • 217 POSTS
what do you hear when you turn the ignition?
does it crank?if not,then it would probably be the starter.
if it does,start with the basics. check to make sure the engine is getting fuel and spark at the cylinders then work your way back.
the alternator will only turn on with the engine running so unless you just discharged a brand new battery in 2-3days while running the car,its very unlikely.
Jan 21, 2008 at 7:55 PM
