So I checked the compression. Three cylinders had around 165 psi but number 2 had zero.
What are my chances that this could be a broken valve spring or stuck valve or anything that could be seen and fixed without pulling the head ?
On my numerous trips to the junkyards, I just happened to notice several Integras with the valve covers off and the DOHC camshafts, etc. removed. Makes me wonder if this is a common problem with this model and there might be a Technical Bulletin on it. I know the dealer is not going to fix anything on a 22 year old car whether its a common defect or not.
Oct 23, 2009 at 6:44 PM
