1986 Acura Integra cahnging clutch
KYLE F CROSS
Transmission problem
1986 Acura Integra 4 cyl Two Wheel Drive Manual
how do I change a clutch for a 1986 integra
Jun 23, 2009 at 9:38 AM
F4I_GUY
  • 3,302 POSTS
Honestly, if you are looking for a full write-up your best bet is to download and print or purcahse a service manual at a local parts store. This way you will always have the instructions right infront of you.
If you get stuck on something or have a specific question I can answer them for you, but its pretty straight forward. Remove linkage, axles, clutch cable, starter, ground cable, transmission bolts, support engine remove mounts and remove transmission.
Jun 23, 2009 at 10:02 AM
