2005 Acura EL over heating when driving
140,000 MILES • 4 CYL • FWD • AUTOMATIC
MZEITOUN
  • 11 POSTS
Hi there,
My car is over heating while I am driving. When I stop my car, temperature goes back to normal but when I drive it over heats.
Basically here is what is going on exactly: I drive to work, turn on my vehicle, drive about 7 minutes with normal temperature and blowing heat inside vehicle, after 7 minutes heat gets cold and temperature starts rising, when I stop the car it goes back normal. It does this for about 5 minutes and then heat starts blowing again and temperature is stable. This cycle repeats. WHAT THE HELL IS GOING ON? I am so frustrated..
I changed thermostat, I checked radiator and jerked it for air bubbles. It has been going on for a while now. what the hell..
Dec 22, 2009 at 8:31 AM
F4I_GUY
  • 3,302 POSTS
This vehicle is common for headgasket failures. You may want to have a leakdown test performed. First check the basics though (coolant level, thermostat, radiator, cooling fan)
Apr 24, 2010 at 5:47 AM
