2004 Acura EL changing engine and cabin air filters
40,000 MILES • 4 CYL • 2WD • AUTOMATIC
RICHEERICH
Hello, I have two questions: 1) how do I access the engine air filter compartment, there does not seem to be any clips
2) How do I access the cabin filters for this car
Sep 23, 2008 at 10:18 PM
IMPALASS
  • 3,112 POSTS
Hello, Unless my book is wrong, for 2004, Acura I show models, 3.5RL, NSX, RSX, TL, and TSX. I don't show an EL model. The only models with 4 cyl are the RSX and TSX. The information I am giving you is for the RSX. Hope this helps. For the Engine Air filter 1. Remove the clamp (A) and the screws (B), then open the air cleaner housing cover (C). 2. Remove the air cleaner (D) from the air cleaner housing (E). 3. Install the parts in the reverse order of removal.
https://images.2carpros.com/forum/automotive_pictures/248015_Engine_Air_Filter_1_1.jpg
https://images.2carpros.com/forum/automotive_pictures/248015_Engine_Air_Filter_1.jpg
Cabin Air Filter Dust and Pollen Filter Replacement The dust and pollen filters should be replaced every 30,000 miles (48,000 km ) or 24 months whichever comes first. Replace the filters more often if the air flow is less than usual. 1. Open the glove box. Remove the glove box stop on each side, then hang the glove box down.
https://images.2carpros.com/forum/automotive_pictures/248015_glove_box_1.gif
2. Remove the filter lid (A) from the blower unit, then pull out the first dust and pollen filter (B). Slide the second filter to the left, and pull it out.
https://images.2carpros.com/forum/automotive_pictures/248015_glove_box_2_1.gif
3. Remove the filter (A) from the housing (B), and replace the filter. 4. Install the filters in the reverse order of removal.
Oct 11, 2008 at 6:27 AM
