2002 Acura EL air filter replacement
142,000 MILES • 4 CYL • FWD • AUTOMATIC
OPS440
how to change the engine air filter ? tried un screwing a couple of screws but one got jammed not sure if all screws are really needed cause i might have to break it off in order to get the cover off thanks...im hoping im taking off the right cover. thanks
Mar 8, 2009 at 9:00 AM
F4I_GUY
  • 3,302 POSTS
Yes all the screws must come out. Unforunately on these models the screws get real rusted.
Try pry up on the filter housing with a prybar while loosening the screw, sometimes this works. If it doesn't, you'll have to cut the head off.
Mar 26, 2009 at 10:59 AM
