Steering fluid is overflowing from the reservoir?
133,000 MILES • 4 CYL • 2WD • AUTOMATIC
RAMESH RAMSARRAN
Jul 22, 2008 at 5:42 AM
SQM
  • 6,383 POSTS
The power steering fluid can overflow if it was filled more than the full mark.
Was the fluid topped off recently?
Did it overflow through the cap, or did it overflow when the cap was removed with the engine running?
Keep in mind that the fluid can overflow if the cap is removed with the engine running.
Are you getting any noises from the power steering?
Please let me know what else you might experience.
https://www.2carpros.com/articles/power-steering-problems
Feb 1, 2022 at 12:09 PM
