Could be many things. Are the tires the same side to side? equal air pressure? If so, you may be looking at a caliper or caliper slide that is hung up and not releasing. Remove the wheels and see if you can move the calipers on their slides, if not, remove,clean and relube the slides.If they are free, then it is most likely the caliper, but front end alignment can also play a role in brake pulls
Apr 9, 2008 at 9:01 AM
