2000 Acura EL Replace door look motor
105,000 MILES • 4 CYL • FWD • MANUAL
SUPERWOLFY
How I do replace the rear door look electric motor? Do you have pictures of it.
Thank very much,
Jan 28, 2010 at 7:08 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Assuming you mean the lock actuator.....steps are below..
REMOVAL & INSTALLATION
Disconnect the negative battery cable.
Remove the door panel by removing the appropriate fasteners and wiring harnesses.
Detach the wiring harness from the door lock actuator.
Remove the fasteners and then remove the door lock actuator.
Installation is the reverse of the removal procedure.
Jan 28, 2010 at 7:49 AM
SUPERWOLFY
Thank bluelightnin6, I understand the process showed. Don't you have any picture or where can I find it. The Acura is my son new car and I never worked on it. Maurice from Québec City.
Jan 28, 2010 at 8:07 AM
BLUELIGHTNIN6
  • 16,542 POSTS
sorry but where it is a Canadian model and I am U.S. based, I can't find any more details other than just replacement steps. Here are some more detailed steps to removing the door panel though, maybe it will help a bit more..It's the biggest part of the job, the actuator itself just disconnect the wiring harness then unbolt a few fasteners and it will come out.
"""There are screws securing that door panel. Two small philips screws behind the door handle - use a tiny flathead screwdriver to pry the cover plate off and get at them. Then open the door grip up using a panel popper (princess auto, canadian tire, costs like 8 bucks). There's a pair of philips screws there too, you have to reach in pretty deep to get them though. Then just grab the bottom edge of the plastic panel and pull outwards firmly. You'll hear the clips popping out one by one, till you get to the top, then you can lift the panel up and off the door.
Before you put the panel back, pull off the front sail panel triangle dealie (the one behind your side mirror mount, it's only held in with a single metal clip), THEN install the door panel. Then pop the sail panel triangle thing back on. """
Jan 28, 2010 at 9:50 AM
SUPERWOLFY
Thank very much. I thing that I will be all right with these informations. Now I have to find a used part and it same very rare. Maurice.
Jan 28, 2010 at 11:11 AM
