2000 Acura EL door locks
144,000 MILES • 4 CYL • 2WD • AUTOMATIC
LMHAMM
Where is the driver's door lock actuator located
When you remotely lock or unlock doors the the drivers door doesn't unlock.
When you manually lock driver's door all doors lock
Is the actuator the problem?
Jul 13, 2009 at 2:30 PM
KHLOW2008
  • 41,812 POSTS
Hi lmhamm,
The door lock actuator is located inside door panel atttached to the door latch assy.
The symptoms indicates a fault with the door lock actuator motor or wiring circuit.
Jul 31, 2009 at 4:14 AM
TLW23
I have the same problem with my 98' EL
So the suggestion would be to check the actuator and the wiring?
Jul 5, 2012 at 5:38 PM
