2000 Acura EL Air Conditioning Problem
110,000 MILES • 4 CYL • FWD • AUTOMATIC
IANMCD323
My air conditioning was working great, until I had my fuel injectors cleaned. It may have been a coincidence but the AC quit right after that.
I tried recharging it, and there seems to be pressure in the system. When I turn on the AC it gets cold for about 30 seconds but then there is a cyclic sputtering noise from in front of the front passenger's seat and the AC stops working.
I have also tried injecting a leak filler into the AC system, this didn't seem to help.
HELP!
May 15, 2009 at 2:23 PM
DR LOOT
  • 2,311 POSTS
it could be a couple problems, first of all you may have a bad pressure switch that switch is located on the high side hoes just follow it until you find a little spending unit with two or three wires, you can make a jumper and bypass the switch if it stays on then you have a bad switch, but it sounds to me like because of the noise for compressors making you may have a bad clutch, it will run for a little bit until he gets hot than the clutch will not stick.
Aug 26, 2009 at 6:48 AM
