1998 Acura EL k frame replacement
145,000 MILES • 4 CYL • 2WD • MANUAL
TERRY NOFTALL
how long should this replacement take????
after the job begain i was told it well take about 10 to 12 hr's to replace!!!
Mar 30, 2008 at 7:48 AM
ARC_55
  • 66 POSTS
that time seems fair for RE and RE.
Removal of
sway bars, struts, lower ball joint, outer tie rod ends, seperate rack from steering shaft, rear motor mount, exhaust, remove from body and support engine, tranfer rack, sway bar, control arms to new frame and reinstall and alignment.
Considering all that 10-12 hours seems reasonable.
Feb 16, 2009 at 11:27 AM
