1998 Acura EL BRAKES MALFUNCTION
135,000 MILES • 4 CYL • 2WD • MANUAL
NUSRATM
Hi, the brake pedal in my car seems to start working when the brake is pushed in till it gets close to the floor. But, if i suddenly slam the pedal, it seems to grab right away. could there be a problem in the brake pedal cable? or is it a master cylinder problem? or brake pads?. I dont hear no squeeling or screeching coming from the brakes so i thought it could't be coming from the pads. Any suggestions?
Nov 3, 2009 at 6:54 AM
MERLIN2021
  • 17,250 POSTS
with 135,000 miles, it could be a leaking caliper, pull them off and peel the protective rubber boot back a bit and see if any fluid drips out. The rears are more likley than the fronts to leak but any one of them could be, I've seen it on cars with 40,000...
Nov 3, 2009 at 7:00 AM
NUSRATM
Hi, thanks for your reply. I was gonna say that when I do press down on the brakes, the car begins drift off to the left. Do you have a solution for this? thanks in advance.
Nov 5, 2009 at 8:17 AM
MERLIN2021
  • 17,250 POSTS
When a car pulls to one side, the calipers or brake flex hoses are bad, the right side is not functioning as well as the left. Maybe it's the caliper with the leak...
From Honda Service News   On all Honda models, if you're manually bleeding the brakes, make sure whoever's pumping the brake pedal pushes it only halfway to the floor. If the pedal is pushed all the way to the floor, you run the risk of driving the master cylinder secondary piston into any sediment or deposits that may have collected on the piston cylinder walls. If this happens, the piston seals can get permanently damaged and cause a leak. You can also avoid this problem entirely by using pressure bleeding equipment. This also appies to Acura.
Nov 5, 2009 at 6:13 PM
JOHNPARKER99
  • 5 POSTS
On all Honda models, if you're manually bleeding the brakes, make sure whoever's pumping the brake pedal pushes it only halfway to the floor. i think this is the right reason!
Apr 16, 2010 at 12:57 AM
MERLIN2021
  • 17,250 POSTS
Me too John!
Apr 16, 2010 at 2:02 AM
AMBOTANNE
Hello guys!!
I have the same issues concerning brake malfunction.
This forum really helped a lot.
Thank you for the information guys!
Jun 4, 2010 at 1:05 AM
MERLIN2021
  • 17,250 POSTS
Glad too help, thanks for the feedback.
Jun 4, 2010 at 10:55 AM
