1997 Acura CL P0420 Catalyst Code
FBURKS
97 acura cl 2.2 120k miles the code indiacates catalyst system efficiency below threshold Bank (1) any idea on how to correct
Oct 29, 2007 at 3:21 AM
LOSTINMARS
  • 222 POSTS
replace the catalytic converter and based on the mileage the 2 o2 sensors as well.
p0420/p0430 are 2 of the most solid codes out there. the only way i'd say it might be something else is if the car was newer and the miles very low.
Oct 29, 2007 at 6:14 AM
Suggested Repair
Replace the catalytic converter and both oxygen sensors, given the high mileage. P0420 is typically a reliable catalyst-efficiency code on a higher-mileage vehicle.
Conversation Summary
The owner of a 1997 Acura CL 2.2 with 120,000 miles asked how to correct P0420, catalyst system efficiency below threshold on bank 1. The expert recommended replacing the catalytic converter and both oxygen sensors, noting these codes are usually reliable except on newer low-mileage cars.
