2001 Acura CL Turn Signal/Brakes
115,000 MILES • 6 CYL • FWD • AUTOMATIC
SBWALLACE6
I have my right turn signal that stays lit solid whenever I apply brakes-- even when the signal's not turned on, the signal lights up when I brake.
If I'm not braking, the signal works as normal, but is definitely making a louder than usual "clicking" then it's on.
The left signal works fine, and braking does not effect the left signal when it's on. Just the right.
Suggenstions?
Sep 27, 2010 at 7:18 AM
  • 75,988 POSTS
Sounds like the brake circuit is shorted to the right turn signal circuit-inspect and test the wiring
Sep 27, 2010 at 5:32 PM
SBWALLACE6
It turns out it was the wire harness for the trailer hitch installed by U-Haul; cost me only $65 but I feel U-Haul ought to cough up the dough for this (fat chance I'm sure).
Sep 28, 2010 at 1:25 PM
