2001 Acura CL Slipping Gear
75,000 MILES • 6 CYL • 2WD • AUTOMATIC
TONYTRAN66
I just bought this car as used and soon this problem is occurring.
This car has 5 speed and also has both of manual and automatic transmission. 8 out of 10 times the gear gets slipping right around 30-40 mile (believe it is gear#3) no matter it is on automatic or manual mode. I can feel the engine starts dragging/pulling heavily before it starts slipping then becomes normal after 40 mile or so. The TCS light also comes on occasionally when this happen.
Apr 21, 2009 at 12:29 PM
KHLOW2008
  • 41,812 POSTS
Hi tonytran66,
Symptoms indicates a faulty clutch or its control for the particular gear that is slipping.
Since CEL is showing, get a scan done to retrieve the trouble code and let me know the exact code. We shall see what is causing it.
May 28, 2009 at 7:28 AM
