2001 Acura CL Running Ruff
2001 ACURA CL
20,200 MILES • 6 CYL • 4WD • AUTOMATIC
COGRAPER
My check engine light has came on and the VSA light also. When the car is started it runs alittle ruff and once I give gas if levels out. Also when I pull off the check engine light blinks on and off and comes back on. Can you tell me if it a sensors or coil?
Sep 19, 2010 at 1:19 AM
KHLOW2008
  • 41,814 POSTS
Hi cograper,
You need to retrieve the trouble codes to know what is causing the problem
Get a free scan done at Autozone and come back with the EXACT trouble code. Do not replace anything recommended until they have been tested and confirmed to be bad.
Sep 19, 2010 at 1:28 AM
