2001 Acura CL Heater Motor running
111,000 MILES • 6 CYL • FWD • AUTOMATIC
SNS1970
We just replaced the battery in our Acura and now the heater fan/ won't quit running. We can change the temp, but not turn on the A/C. Tried simply shutting off with the control and that doesn't work. Had to pull the fuse to gt it off.
Jul 6, 2008 at 9:39 AM
IMPALASS
  • 3,112 POSTS
Hello, if I understand you correctly, the blower fan for the AC/Heat will not shut off unless you pull the fan fuse? Have you checked the codes? Auto Zone and O'Reilly's does this for free. I think it may be the blower motor resistor. "B" in the pic
https://images.2carpros.com/forum/automotive_pictures/248015_Blower_1.jpg
Oct 10, 2008 at 5:53 PM
