Hi is there a way to manually put the power window up, until I can get it fixed
Apr 22, 2009 at 1:38 PM
CARLIFE65
✓Experienced Mechanic
the window switch,and master switch are actually wired in series, a problem with either switch affects motor operation. now by jumping the terminals to B+ AND Ground. Reversing the connections should reverse the direction of the motor,raising and lowering the windor. here a picture of window motor.
