When I press on the brakes, it is difficult to press and not as sensitive in braking as it has been in the past. The pads and rotors were checked and thought to be ok, the brake fluid is full, and there are no codes. The car will stop if you push harder than originally. Would appreciate some feedback on the problem. Many thanks in advance. James
Dec 22, 2008 at 2:50 PM
