2001 Acura CL Brakes losing sensitivity
75,000 MILES • 6 CYL • 2WD • AUTOMATIC
JJMSMOOTIE
  • 8 POSTS
When I press on the brakes, it is difficult to press and not as sensitive in braking as it has been in the past. The pads and rotors were checked and thought to be ok, the brake fluid is full, and there are no codes. The car will stop if you push harder than originally. Would appreciate some feedback on the problem. Many thanks in advance. James
Dec 22, 2008 at 6:50 AM
  • 110,244 POSTS
Does the car have rear disc or drum brakes?
Dec 22, 2008 at 7:39 AM
JJMSMOOTIE
  • 8 POSTS
The rear brakes are disc brakes
Dec 22, 2008 at 8:32 AM
  • 110,244 POSTS
Hi Again:
It could be caused by different composition brake materials if they have been replaced. Also, the slides on the calipers or pistons may be getting tight or corroded. Do you still have a good solid brake pedal? Does the brake pedal seem to be harder to push? If so, check for a small vacuum leak going to the brake booster. If nothing is found, you may want to have the brake booster vacuum checked.
Have a great Christmas!
Dec 22, 2008 at 12:15 PM
