2001 Acura CL Air suddenly stoped working
2001 ACURA CL
195,000 MILES • 6 CYL • 2WD • AUTOMATIC
JKIMP
The Air conditioning in my Acura all of the sudden stopped blowing cold air. Blower works fine. The air has been working. Have used every day this summer as the heat & humidity has been pretty bad this summer. Anyway, is this a repiar a do-it yourselfer can do or am I better off taking the car in to a mechanic? Anyone had the same thing happen?
Aug 20, 2010 at 12:32 AM
KHLOW2008
  • 41,814 POSTS
Hi jkimp,
This is a common problem that most people would face when some components fails.
The A/C system should be done by ttrained personnel if it requires charging and discharging of the freon.
For DIY, those things that you could check, the electrical systems would be within means.
Check if the compressor is engaging when it is not blowing cold air.
Check for blown fuses.
Check the compressor clutch relay and circuit.
Aug 20, 2010 at 12:59 AM
