1999 Acura CL The horn on my 1999 acura cl does not work
110 MILES • 4 CYL • FWD • MANUAL
HDEPINA
My horn stopped working once and I got it working by moving and lightly knocking on the horn under the hood. Now after a month or so it no longer works anymore even after doing what I did before.
Any ideas what else I can do? I have checked the fuses but I can’t find a specific fuse for the horn.
Feb 2, 2009 at 5:00 AM
ZACKMAN
  • 4,202 POSTS
Remove the wire harness from the horn and attach voltmeter probes to the wires. Have an assistant press the horn button/switch and see if you have voltage going through the voltmeter. If you have voltage, replace the horn with a new one.
Mar 3, 2009 at 2:59 PM
