Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Acura
CL
Engine
Computer
Clear Codes
1999 Acura CL RESET CHECK ENGINE LIGHT
1999 ACURA CL
151,250 MILES • 6 CYL • FWD • AUTOMATIC
REDACURA
MEMBER
1 POST
HOW DO I RESET THE CHECK ENGINE LIGHT? CAR IS RUNNING GREAT. IT HAPPENED THIS MORNING FOR THE FIRST TIME.
Mar 6, 2010 at 2:26 AM
KHLOW2008
Experienced Mechanic
Hi REDACURA,
You can either use a scanner to reset, disconnect the battery or remove the back-up fuse.
The CEL would come back again if there is a fault which have not been recified.
Get a free scan done at Autozone to see what is causing and you can have the code reset as well.
Mar 8, 2010 at 11:44 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
