HOW DO I RESET THE CHECK ENGINE LIGHT? CAR IS RUNNING GREAT. IT HAPPENED THIS MORNING FOR THE FIRST TIME.
Mar 6, 2010 at 10:26 AM
KHLOW2008
✓ASE Certified Mechanic
Hi REDACURA,
You can either use a scanner to reset, disconnect the battery or remove the back-up fuse.
The CEL would come back again if there is a fault which have not been recified.
Get a free scan done at Autozone to see what is causing and you can have the code reset as well.
Mar 9, 2010 at 7:44 AM
